$TX.$TOUCH_ENB variable field protected
  • skalactik
  • July 27, 2016 at 11:26 AM
  • skalactik
    13
    111
    Hello fellow members,
    I'm trying to disable the touch screen capability as stated in this post : https://www.robot-forum.com/robotforum/fan…61840/#msg61840.
    My problem is the $TX.$TOUCH_ENB is field protected and i can't change it (tried it also in controlled start with the same result).
    There is probably something i miss or i do wrong but i can't find what it is.
    Anyone know anything about this issue ?
  • Nation
    Typical Robot Error
    556
    1,937
    • July 27, 2016 at 10:29 PM
    You can change protected variables from a tp program.
    Just create a tp program with the following line, and run it.
    : $TX.$TOUCH_ENB=(0) ;
  • dkz9496
    • December 6, 2022 at 2:14 AM
    How can we add above code in new program in teach pendent?
    Help would be appreciated.
    Thank you
  • TitusLepic
    113
    7
    442
    • December 6, 2022 at 6:02 PM
    [INST] > Miscellaneous > Parameter Name
