R30-i ... positions are not stable
  • sajad
  • July 27, 2016 at 7:55 AM
  • sajad
    :help: :help:
    hi every one, i have a R30-i controller
    i have a strange problem, i modify some points in program and after test the positions are OK.
    after some days when i check the positions they are NOT OK, there is shift in positions.
    please let me have your comment
    best regards
  • Iowan
    686
    • July 27, 2016 at 2:13 PM
    Positions or Position Registers?
    Are the values changing, or is the robot drifting?
  • Nation
    Typical Robot Error
    539
    1,921
    • July 27, 2016 at 10:32 PM
    Is the robot properly bolted down? Had this happen to me on a couple of occasions.
  • sajad
    • July 28, 2016 at 4:32 PM
    really i am not expert on fanuc
    for change the position, i run a point and when robot go to the target, i change the position in jog mode and then press shift+touchup
    after test it is OK, after some days of work i check it manual but positions has been changes in Z and Y direction.
    did anyone see this problem before ?
    best regards
  • skalactik
    13
    111
    • July 28, 2016 at 4:44 PM
    What process are you working on ?
    What type of job is this robot doing ?
    What and when does your problem happen ?
  • Iowan
    686
    • July 28, 2016 at 5:12 PM
    Check the Position page and note the values for the XYZWPR. When the position changes, do these values change?
    (You can also highlight the P[] value and check program position before/after to see if someone/something is changing the target value.)
  • avnishoza
    17
    • July 28, 2016 at 5:37 PM
    You can send robot to its Zero position and check witness mark . Usually this happen when on of the robot servo/ gear box is wear out.
    You can give us more info to think..
    1> How old is the robot?
    2> Did you get any maintenance work done on particular one?
    3> What kind of work environment is in robot working on?-- Most importance temperature , wash environment
  • kluk-kluk
    51
    5
    300
    • July 28, 2016 at 11:59 PM
    How much is the shift in positions ?
    Other possible issues can be :
    Not properly grounded cables,
    An encoder that is loose (had this myself, forgot to tighten the bolts after exchanging an encoder)
  • sajad
    • July 29, 2016 at 10:50 AM
    the year of made this robot is 2012
    as i know, no maintenance operation happen on this robot. this robot's job is washing a metal piece with high pressure water (300 bar-65 degree)
    the shift value is about 1 centimeter in z and y direction.
    i checked the bolted, it is OK. i will check the positions value and create a calibration point to periodic check and get a result.
    thank's for your help.
  • Jaymo
    • November 29, 2016 at 7:53 PM
    Did you ever find a solution for this problem? I'm having the same type of issue where the robot will run fine for 3-4 hours and then all of the sudden my x and z positions are off by 6-8mm. I manually adjust the x and z and it will run fine for a couple of hours and then I have to change the positions back to the original settings. I check the zero marks and everything always lines up.
