It is 1111.
From the string 10 f3 10 80-eb f0 1b 25-fd 00 00 04-bd 57 46 27
The hex code is the 0457 that I have in bold which is 1111 in decimal.
It is 1111.
It is 1111.
First, how did you know where exactly in the code to look? I noticed that most DCS codes were the values starting at the fifth number after fd(basically I would find fd ignore the next 4 numbers, 00 00 above, and the code value follows). Second why did you ignore bd, do we ignore everything but numerals?
I think it used to be the way you describe on an older software version. I figured it out by changing the DCS code and comparing the files. I noticed that the 5th, 6th, 9th, and 10th characters after "1b 25 fd" make up the code.
You said it changed from on older software version, do you have any idea where the crossover point is? Is it related to a certain robot software version? I find this confusing because on the 1st page of this thread there are 2 examples of code shown. In the 1st example, reply#6, the DCS code is the 7th-10th characters following EB 15 FD. The 2nd example reply#11 the code is the 5th-8th characters again following eb 15 fd(Assuming Nation is correct and 00 12 are the characters containg the code). The one thing they have in common is the codes both directly follow the characters 7B, but then the code in reply#17 does not have those characters near the code. Any idea of what to make of all of this?
This is what I know.
On version 8.30/P03 and older, it is the 5th-8th characters
On version 8.30/P15 to p31 it is 5th,6th,9th,10th
I tested on HandlingTool and SpotTool+.
I'm not sure at which patch level it changed, but somewhere between patch 3 and 15.
Hello guys,
can you please help me to figure out the mastercode from the attached file. We unfortunatley lost the code.
Thank you very much!
Can you attach syspass.sv?
Sorry not possible, it says file extension is invalid.
Is the picture okay?
Save it as syspass.txt or .jpg. I will rename it later.
Alright, here it is....syspass.txt
Try 2015
Great! Thank you. How did you find out?
There is a guide somewhere on forum.
can we find out the password through this way?
Could you address to that post? I could not find.
Can anyone help me to find DCS code?
1234?
1234?
Nope
Alright, give 9578 a try. Haven't done this in a bit too long. Might have to play around with some syspass saves in roboguide.
