Find DCS code
  • K-Sky
  • July 26, 2016 at 5:38 PM
  • K-Sky
    196
    I have a robot with a DCS code that is no longer 1111, but no one remembers what it is now. Ive looked through most of the DCS variables and have found nothing. I found an older thread on here that mentions syspass.sv, but when I look in syspass.va(cant view .sv files) there in nothing there that looks different from the syspass.va on a robot that I know is still using 1111. Is there something saved within .sv files that is not shown in .va files? Appreciate any help.
    https://www.robot-forum.com/robotforum/fan…sword-recovery/
  • luicar1187
    21
    • July 26, 2016 at 5:51 PM
    From a Backup that you know the code is 1111 load the SYSPASS.SV file, then try it using 1111 again should de it.
  • K-Sky
    196
    • July 26, 2016 at 6:13 PM
    Quote from luicar1187
    Do you know for sure that works? What else might be lost/changed by reloading syspass? Why cant I see the DCS code in syspass.va?
  • luicar1187
    21
    • July 26, 2016 at 6:28 PM
    Yes I am 100% sure i had donde that a couple time, only affects the DCS code.
  • Beejaybarnes
    Guest
    • July 27, 2016 at 11:09 PM
    Yes sir, I have done it a few times myself. Just make sure to go into controlled start to load the Syspass.SV file.
  • K-Sky
    196
    • July 29, 2016 at 8:56 PM
    Quote from Beejmanbarnes
    Learned the hard way it works in controlled start. Technically it looks like you might be able to do it in a cold start, but only if you also know the current code. When I did it in cold start I had to first type in the current DCS code, then it would allow me to use the new code that I loaded in. At least that is how it worked on Fanuc's robots at their training facility when I was there this week. They used a code other than 1111 on their training robots. I loaded in syspass on cold start, it even said something at the bottom of the screen about new code loaded, or code changed or something, after loading syspass. When I made a DCS change it still first needed the old code punched in first, then I could use 1111. Instructor said something about they use a master code, and a DCS code, I didn't really understand what he meant by that, so maybe that is why it needed the old code typed in first. Later he talked to another instructor and confirmed that had I loaded syspass in at a controlled start it would have outright changed the code back to 1111.
  • Kalagaraz
    13
    • November 8, 2016 at 8:55 PM
    Old topic, but I just figured this out and figured I would share it in case someone needs it in future. The DCS master code can actually be read in hexadecimal from the syspass.sv file as shown below. The top file the password is 1111, the highlighted hex is "04 57", the bottom file the password is 9713 and highlighted hex is "25 F1". Just use a hexadecimal to decimal converter to get the password from the hex values.
  • K-Sky
    196
    • November 9, 2016 at 8:00 PM
    I don't exactly understand how you found that. After you open the syspass.sv file how did you know where to look in all of the gibberish and random characters?
  • Kalagaraz
    13
    • November 30, 2016 at 4:00 PM
    Quote from K-Sky
    I noticed DCS code written in plain text in file, then I knew the password was 1111 on the one robot so I converted that to hex, and noticed it came after the words DCS code. So any other code would be stored in hex in the exact same position after DCS code.
  • USURP_RUR
    8
    162
    • January 19, 2017 at 7:33 PM
    What program did you use to open the SYSPASS.SV file?
    I tried NotePad and Word, but it was not laid out like that
  • K-Sky
    196
    • January 19, 2017 at 7:53 PM
    • #11
    Quote from USURP_RUR
    I just open it in Wordpad. But that doesn't do much for you, it needs to be converted. I just went to:
    http://www.fileformat.info/tool/hexdump.htm
    After they open your file you will end up with the screen like Kalagaraz has above. Then you locate the values and convert them. Then just search for a hexadecimal to decimal converter to get the DCS code. I started with a robot that I knew still had the 1111 code. I wish it had been explained a little better, it took me awhile to figure out how he got the screen in his post.
  • dhlg0110
    Guest
    • July 7, 2017 at 12:28 AM
    • #12
    Hello, my dcs password has been changed from 1111, not sure exactly where to look for in sys.pass file
    attached is my syspass file
    Please help,
    Images
      • 244.31 kB
      • 596 × 586
      • 541
    Files
    syspass.jpg_thumb 52.31 kB – 988 Downloads
    Nation
    Typical Robot Error
    552
    1,933
    • July 7, 2017 at 6:11 AM
    • #13
    Quote from dhlg0110
    Please help,
    Looks like it is 0018.
  • dhlg0110
    Guest
    • July 7, 2017 at 10:20 PM
    • #14
    I was told it was 4617, can you explain how you got this number?
    Thank you!
    Nation
    Typical Robot Error
    552
    1,933
    • July 7, 2017 at 10:36 PM
    • #15
    The two numbers after the 7B hex code in your screen shot are 00 12, which is 0018 in decimal.
    4617, which is 12 09 in hex, doesn't appear to be in your provided screen shot.
  • CSaunders
    44
    • July 11, 2017 at 1:21 PM
    • #16
    Ran into this issue once before. Loaded the syspass file in a controlled. When entering the DCS password after file load, was prompted with with "Password change by file load, enter previous password". Didn't know about finding the DCS password in the file, so we loaded and image from a similar robot and restored a fullback up.
    This thread is very helpful.
  • dhlg0110
    Guest
    • July 11, 2017 at 10:42 PM
    • #17
    Quote from CSaunders
    syspass file you loaded has to be the one with password 1111, correct? how do we know? does it change anything else?
  • hosboss2002
    • October 19, 2017 at 10:09 PM
    • #18
    Can you help me find my DCS Master Code. Here is my syspass file.
    I shortened it to start at the DCS.
    0000-01b0: 00 00 0c aa-cd fc 24 7f-44 43 53 5f-43 4f 44 40 ......$. DCS_COD@
    0000-01c0: 10 f3 10 80-eb f0 1b 25-fd 00 00 04-bd 57 46 27 .......% .....WF'
    0000-01d0: 5f 53 00 20-16 2a fd 92-21 10 04 18-20 84 26 fc _S...*.. !.....&.
    0000-01e0: 41 02 39 02-31 dc 56 22-17 21 05 05-05 5e 20 0a A.9.1.V" .!...^..
    0000-01f0: 00 03 24 0d-1e 21 e3 f8-ae 2d ba 2f-d0 2f de 2f ..$..!.. .-./././
    0000-0200: 00 f4 2f 02-3f 18 3f 26-3f 3c 3f 4a-3f 60 3f 6e ../.?.?& ?<?J?`?n
    0000-0210: 3f 00 84 3f-92 3f a8 3f-b6 3f cc 3f-da 3f f0 3f ?..?.?.? .?.?.?.?
    0000-0220: ea f1 2e 90-23 53 55 50-c3 00 11 9c-2b f2 3f 18 ....#SUP ....+.?.
    0000-0230: 04 4f 90 23-46 02 11 01-24 4f 36 4f-76 4f 3e e6 .O.#F... $O6OvO>.
    0000-0240: f5 08 00 02-00 0f a3 4c-a0 41 e4 de-fd b4 4f 00 .......L .A....O.
    0000-0250: aa 20 e8 f3-04 00 04 ff-56 a9 5b 74-26 97 a0 6a ........ V.[t&..j
    0000-0260: 08 eb f0 17-00 9d 42 04-43 4f 0c 5f-eb f0 ca 47 ......B. CO._...G
    0000-026e: 40 c8 4f ea-f1 40 20 41-56 3e 55 3e-59 00 @.O..@.A V>U>Y.
  • beanluke
    32
    • October 19, 2017 at 10:51 PM
    • #19
    check this post out
    https://www.robot-forum.com/robotforum/fan…/pass-unlocker/
  • K-Sky
    196
    • October 20, 2017 at 12:04 AM
    • #20
    Quote from hosboss2002
    Im not good at deciphering this stuff yet, but if im understanding it correctly your code is 1213.
