I have a KRC4 (IP:192.168.0.1) with KLI (IP:180.25.17.100) with an OPC DA server. I want access the server with an OPC DA client in another computer (IP: 180.25.17.10).
I have configured the DCOMs in both devices like in the manual, but when it try to connect the client to the server with (IP:180.25.17.100) it does not get any result.
Then, I tried to run client in the robot and it only found the server using the (IP:192.168.0.1).
Does anyone know what the problem is? or did it happen to you before?
Best regards
Renato Martins
