another way to I/O mapping at KRC4
  • ak
  • July 6, 2016 at 4:36 PM
  • ak
    Guest
    hi everyone
    i am working with Krc4 -V8.2.27. i just want to know :
    is there a way except X44-EtherCAT for receiving digital out put from Krc4 ,for example X11 or other pin?
    TNX for any advise.
  • panic mode
    1,297
    13,141
    • July 6, 2016 at 5:56 PM
    X11 is safety interface, not standard I/O that you are looking for.
    you have several options to add I/O to your robot. the most convenient way is to use Kuka Expansion Bus (X44 on CCU) which is free, but you can use ProfiNet or EthernetIP (paid options).
  • ak
    Guest
    • July 7, 2016 at 7:33 AM
    dear panic mode
    many thanks for taking time and kindly reply.
  • ak
    Guest
    • July 7, 2016 at 9:34 AM
    Hi dear panic
    just something more!
    my controller(Krc4 standard) has already set to EK1100 and EL2809 , EL1809 and else before i got it.but i have another terminals included EL1008 and EL2008 right now. so can i change the configuration of them without Workvisual? for instance on the following path at the KSS:
    Display>Input/output> I/O drivers>Reconfiguration
    actually i have not the WV at this time . asking for that but it will taking time to get it and the project should be ran ASAP.
    your advise would be appreciated.
  • Spl
    5
    178
    • July 7, 2016 at 10:44 AM
    Isn't WorkVisual free? If you don't have it, just send email to KUKA.
  • the leg
    643
    • July 7, 2016 at 12:39 PM
    WV Is on the robot and its free its on the D drive
  • panic mode
    1,297
    13,141
    • July 7, 2016 at 1:31 PM
    Yep... wov is free. And modifying io configuration is quite simple....
