Hi people, hope anybody can make this clear..
As title says, I'm trying to load .jbi files (standard Robot Jobs) to the controller, so I mark the files I want to load, hit enter, hit yes, and the controller freezes for a couple of seconds, then I get "DX200 pendant disconnected" with the blue background, and hitting "OK" or doing nothing makes it reboot anyway; while it's booting again, I have two red LEDs lit solid near the rotary switch on the YIO21 board, and when boot is completed it outputs 3 alarms:
ALARM 0020 [50] - CPU COMMUNICATION ERROR
ALARM 1865 [105] - M-SAF I/O BOARD COMM ERROR
ALARM 1876 [102] - M-SAF I/O BOARD WATCHDOG ERROR
Alarms occur only if I try to load again the same files, turning power off and on again restores the system but I'm stuck here.
Sub code of 1865 says it could be either a failure in YSF21 or YSF22, while sub code of 1876 says "An error in channel 1 of YSF22 board was detected by CPU1 of YSF21 board".
I'm waiting for a response regarding the sub codes from Yaskawa, it's weird that transferring .jbi files triggers communication alarms.
I checked all cables and connections mentioned in the alarm list but I have no clue about what's happening.
Any suggestion?
