x11 - external estop reset
  • RoboticlyChallenged
  • June 29, 2016 at 6:39 PM
    17
    I am running a KRC4 8.3.8
    I have followed the wiring diagram for the x11 plug, found here https://www.robot-forum.com/robotforum/man…krc4-x11-13942/
    All the pins in the x11 are jumped, except the pins for External E-stop (1,2 and 19,20). My external estop is setup on these pins.
    I am running in AUT mode. When I hit the estop button the robot stops and the controller recognizes that the button was pressed. But when I release the estop I cant find a way to clear the message on the controller. It seems as if the controller doesn't recognize that the estop has been released.
    I can provide more information if needed.
    Thank you for any help
  • panic mode
    1,280
    13,083
    • June 29, 2016 at 6:57 PM
    when you press EStop, you get yellow status message that estop is pressed.
    when you release EStop, that message is replaced by red acknowledgement message.
    clear messages and you are good to go.
    17
    • June 29, 2016 at 7:19 PM
    Normally yes. That is what happens when I press the estop button on the teach pendent.
    But when I hit the estop button i have installed, then release the estop, the yellow message doesnt go away.
  • panic mode
    1,280
    13,083
    • June 29, 2016 at 7:59 PM
    your wiring is incorrect or SIB is defective....
    17
    • June 29, 2016 at 8:29 PM
    Ill take a look at the wiring of our x11 plug again, thanks
