Hi
i want to turn off DO[65] when fault and i want use BGlogic program to do that.
from Menu -> Setup -> ... I don't find the BGlogic option.
My question :
How can i write a BGlogic program using fanuc S-430 iW and R-J3?
Hi
My question :
I believe Background Logic is an option. Contact Fanuc for help.
If you don't have the BG option (And it sounds like you do not) look into CONDITION MONITOR's
Or maybe you can use an autoexecute program?!
Instead of BG logic.
Best Regards
I used Condition monitor instruction to turn off DO[10] when fault.
My programs are :
TP program :
MONITOR cond
L P[1] 50 mm/s CNT100
DO[10] = on
C P[2]
P[3] 50 mm/s CNT100
DO[10] = off
MONITOR END cond
CH program:
when UO[6] = on and DO[10] = on, call action
action program:
DO[10] = off
MONITOR cond
when i run TP program .... CH program stat is active, but when there is a fault it dosn't turn off DO[10].
i think that the action program don't work when fault.
I appreciate any insights you have
