Purpose of PGNO??
  • I just need some clarity of the purpose of the PGNO.. like can I use that to call a program and not the program name? Using Directory loader; manual says I can change the old program number to a new program number, but why would you ever need to do that unless you can call it by the number?
  • if using EXT mode sure, why not...
    use SPS to pass the string with program name (instead of PGNO), use CWRITE to select program, and external start to start it...
  • That's awesome, i knew there is always a way. Can you elaborate, using CWRITE I'm weak in this category.
    Would it be something similar to this?
    IF $IN[10]==TRUE THEN ;Start
    CWRITE($CMD,STAT,MODE,"RUN /R1/variable") ; where i can set the program to a variable and define it in the .sps
    ENDIF
    I don't think i know how to make the program into a variable that i an call.
    I also need to turn the program number into a string so i can add to the string so the program names match.
    Edited once, last by TickTack ().
  • You'll have to construct a string for the run command. This is easy enough to do using SWRITE.
    DECL a string variable of sufficient length.
    Clear the string variable.
    SWRITE the string variable with something like SWRITE (StringVariable[], State, Offset, "RUN /R1/%s", ProgramNameString[])
    CWRITE ($CMD, STAT, MODE, StringVariable[])
    You'll want to read up on the SWRITE function in detail, it's a bit involved. Very handy once you grasp it.
