Hole cutting
  • popbot
  • May 25, 2016 at 2:02 PM
  • popbot
    73
    I've been getting my self familiar with this shape generation software. I need to use it to cut round holes mostly. I have cut sample holes of each of the preloaded shapes that came with it. attached is a photo of a few of these samples. Note the hex shaped hole. the points are sharp on one side, and almost a circle on the other side. The rectangle should have been a 20mm by 30mm. Im not sure what you would call the shape I ended up with. I'm sure this is a symptom of something. Can someone tell me what i'm seeing here?
    Images
      • 123.82 kB
      • 640 × 480
      • 39
    Files
    IMG_0542.JPG_thumb 34.55 kB – 115 Downloads
    Do robots dream?
  • Nation
    Typical Robot Error
    522
    1,900
    • May 25, 2016 at 4:17 PM
    Odd. Can you post the program the software generated?
    I would lean toward a slightly off mastering for the odd shapes.
  • popbot
    73
    • May 25, 2016 at 5:08 PM
    A "CD" termination type I understand only works with the AccuPath option. How can I tell if I have AccuPath option?
    Images
      • 148.64 kB
      • 640 × 480
      • 72
    Files
    IMG_0543.JPG_thumb 33.78 kB – 108 Downloads
    Do robots dream?
  • HawkME
    567
    10
    3,268
    • May 25, 2016 at 7:38 PM
    I think the CD termination type is causing your issue. You are telling it to round the corner 12mm away, so not even close to making a sharp corner. You can try reducing the CD value to 0 or 1, or you could test with a CNT0 or CNT5 termination. If you want a perfectly sharp corner you could use Fine termination, but it will stop briefly at that point.
    What shape generation software are you using? Is it creating the program for you? If so, you might be better off creating your own programed path so you can fine tune it and understand how all of the parameters work.
    Edited once, last by HawkME (May 25, 2016 at 7:41 PM).
  • dmbj
    14
    202
    • May 25, 2016 at 9:24 PM
    dose the program software know what size your end mill is?
    yes mastering could cause some of this, so could a bad TCP
    the off angle rectangle looks like a U frame problem
    Edited once, last by dmbj (May 25, 2016 at 10:50 PM).
  • popbot
    73
    • May 25, 2016 at 10:55 PM
    I'm using a 1/2" fiberglass cutting bit. The software we use requires only the center of the hole to be recorded. It calls out a calculation program that I cant view. Then a cut program that I posted here.
    Do robots dream?
  • trobo0009
    • February 20, 2024 at 3:23 AM
    Is there a way to implement this same idea to a CRX collaborative robot programming? Thank you.
  • PnsStarter
    90
    325
    • February 20, 2024 at 12:22 PM
    Hi trobo0009,
    I think you can order "shape generation 3 (R801)" for you crx...
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • Beek
    36
    • February 21, 2024 at 6:40 PM
    What robot are you using to cut this shape?
  • ROBOT_G
    23
    241
    • February 24, 2024 at 5:19 PM
    Never used CD for cutting always used CNT. Did a lot fancy shapes waterjet cutting.
  • Shellmer
    52
    5
    161
    • February 25, 2024 at 6:48 AM
    • #11
    When doing complex forms like circles, what I found is that circular moves work better with CNT100 than with any other termination type as CR.
    With other shapes like squares ot hexagons, the better results you will get will be using fine terminations, that is the only real way to ensure it will do a "sharp" cut. You can try with cnt0 or CR1... but on my experience, you need to get a compromise you are comfortable with, if you need accurate forms, you will be slower, if you do not need perfectly accurate forms, you can be faster.
    If you want to do a perfect cut, assuming you use 4 points, you will need to go from point A to B, then to C, then to D, then to A and then to B again. This is because if you stop on the same point as you started you will most probably not cut everything..
    Softwares used to generate paths for this applications are usually pretty bad at their job, often using more points than needed when shape is small (this slows down the robot movement a lot) or incorrect termination types. As this softwares are simulators, they are not running a virtual machine with the OS like abb or fanuc does with their softwares. This causes the generated paths to be trash most of times.
    Finally, if you are using a waterjet, the upward force that cause the pressure can mess up with your path, that is the reason you need an accurate payload, and even with it you may need to trigger the valve opening outside the cutting area so the initial kick doesn't affect the cutting path (this is usually done triggering it above the material that will be discarded with the cut and then moving to the first point.
    You can also try reducing accelerations, but I would not do it without first ensuring payload is correct and termination types from the path are correct.
