Communication between 2 robots
  • luicar1187
  • May 13, 2016 at 6:27 AM
  • luicar1187
    21
    Hii All
    I got a project where one robot needs to send an offset to another robot, the robot needs to send the offset in a PR, which is the best protocol to do this kind of application ? I am tempted to use socket messaging but if somebody have a better idea i am all ears..
    Thanks for your Help
  • skalactik
    13
    111
    • May 13, 2016 at 9:48 AM
    If the offset is simple enough (like one dimensionnal) you could simply use the IO as groups ?
  • rumblefish
    19
    131
    • May 13, 2016 at 10:50 PM
    It really depends on what comm/fieldbus options you have available? Existing robots or to be ordered?
  • simonsRG
    • May 15, 2016 at 10:22 PM
    You can easily do it with Modbus via RS232 - it's build in, point-to-point, and all you need to purchase is two plugs for ~30$.
    Then you wirte simple script in Karel like:
    [Sending robot]
    Create port (file) -> Open port (file) -> Send register value -> close port
    [Receiving robot]
    Create port (file) -> Open port (file) -> While (1) listen to port -> if received, save and close.
    If you need code I could send you in 2 days but you can just use examples from Karel manual.
  • ESIELI
    10
    5
    275
    • May 16, 2016 at 2:17 PM
    Quote from luicar1187
    Hii All
    What controller are you using?
  • luicar1187
    21
    • May 18, 2016 at 6:17 PM
    the controller i am using is R-30iB, version 8.20
    thanks
  • lexx905
    82
    • August 14, 2016 at 7:47 AM
    Quote from simonsRG
    [Sending robot]
    [Receiving robot]
    Yes. Only more convenient to use TCP
