Wow! How did you make this Mickey Mouse path program?
Setting up some I/O on a KRC2 ed. 2005
- Wall-E
I'd imagine Inkscape, with the GCode plugin, could have done most of the vector art conversion to path coordinates, but would have required additional work to convert to KRL, and to "wrap" the path around the cylinder.
Fusion360 could probably do it, too, but the conversion to KRL might be tricky. ISTR that there's a 3rd-party KLR plugin for F360, but I've never used it.
Blender could probably be programmed to generate the path. RoboDK could probably also do at least part of the work
Sorry, this picture was taken with the main switch off.
Here's what it looks like.
As you can notice, the MFC card does not flash it's LEDs.
I attached the current IOSYS.INI file ; as you can see, the Devicenet driver has not been activated.
I guess that's why the LEDs are dark...Hey Wall-E I seem to have the same problem as you, could you please share a more detailed picture of your connection between the Bechkoff controller and the MFC card?
