ik ben begonnen met de opstart van onze load robot.
hiervoor volg ik een stappenplan.
één van de eerste zaken is het uitvoeren van een comment tool.
in het stappenplan stond
Plaats de bestanden "IOCOMMNT.kl"; "IOCOMMNT.PC" en "IOLIST.DT" op de robot via USB.
Start het programma "IOCOMMNT" en volg de instructies op het scherm.
Hello All,
I'm new at fanuc robot programming (I have programmed for years other robot brands but at Fanuc I'm new).
I was trying to load and run a karel file. It is a standard karel file that runs on other fanuc robots, so there is nothing wrong with the karel.
I have the KL file and have compilated it and the translation was ok and now i have the ls file and I was able to load the ls file.
but I can not see the file if I choose select, or I can not call the routine, and I can not see any karel variable when I choose data and karel vars.
I have checked and the service var $karel_enb I have set on 1.
If I try to reload the file, I get a notice that the file already exists.
does anyone has any Idea why I can not see the karel file?
thanks for reply.
