I have a DX100 controller with Ethernet function enabled and Ethernet FTP enabled.
I can ping the controller from the PC; I can connect from the PC to the controller via FTP, read JBI files and I can even create a new JBI file.
I can configure a FTP Profile on the DX100 and connect to an external FTP server (located also in the PC) and save the DX100 data onto it. I can also Load new JBI files from the FTP server.
SO, all the configuration work seems to be ok. BUT, I cannot Overwrite a JBI file: not by connecting to the DX100 via FTP and uploading a JBI file that already exists, nor by trying to LOAD an existing JBI file from the FTP server on the PC. I know about parameter RS059 and it value of "2", but that seems to only refer to "USB device" ... With RS059 set to "0" I cannot overwrite from the USB, with it set to "2" I can .. but neither "0" nor "2" in the RS059 parameter allows me to overwrite via FTP.
The error I receive when trying to LOAD an existing JBI file from the FTP is "ERROR 2040: Defined JOB Name"
The manual I am using is this: http://www.motoman.com/motomedia/manuals/docs/157178-1CD.pdf (It is on the motoman public server, so I think I am not breaking any rules) and it doesn't mention any special configuration in order to be able to LOAD from an external FTP server.
Hope some of you guys have some information about this.
Thanks,
Ionut
