multypass program
  • potibo83
  • March 8, 2016 at 12:42 PM
  • potibo83
    Guest
    hello,
    I´m programming with a kr16 controlled by krc2.
    I'm doing a multipass program for welding application.simply I want to repeat the cycle between two points 50 times but increasing the height one millimeter on each pass. normally I program in fanuc and in that case it is done by PR but in KUKA i don´t know how . i have programmed the loop and cycle counter but if someone could tell me how to increase height 1 mm each pass between P1 and P2 please? the code that I have scheduled is this:
    MULTIPASS.DAT
    DECL INT COUNTER=0
    MULTIPASS.SRC
    INI
    PTP HOME=10% DEFAULT
    LOOP
    PTP P1 VEL=10% PDAT1 TOOL[1] BASE[0]
    PTP P2 VEL=10% PDAT1 TOOL[1] BASE[0]
    COUNTER=COUNTER +1
    IF COUNTER==50 THEN
    EXIT
    ELSE
    ENDIF
    ENDLOOP
    PTP P3 VEL=10% PDAT1 TOOL[1] BASE[0]
    COUNTER=0
    Thank you
  • ceyhan
    7
    • March 8, 2016 at 1:09 PM
    Hi potibo83,
    I'm not trying this code, but it is posible looks like this;
    INI
    ;TCP IS NEAR AT WELDING POSITION WITH P4
    PTP P4 VEL=10% PDAT1 TOOL[1] BASE[0]
    COUNTER=0
    REPEAT
    XP1.Z=XP1.Z+1
    XP2.Z=XP2.Z+1
    COUNTER=COUNTER +1
    UNTIL COUNTER>=50
    END
    SkyeFire
    1,052
    9,431
    • March 8, 2016 at 2:02 PM
    Easiest way to do this is to create a Base that has one axis (say, Z) perfectly aligned with the "layering" effect you want to create, then manipulate the Base inside your FOR loop. Something like:
    DECL FRAME Shift
    DECL INT Index
    $BASE = BASE_DATA[1] ; nominal Base
    FOR Index = 0 TO 50
      Shift = $NULLFRAME
      Shift.Z = Index
      $BASE = BASE_DATA[1] : Shift ; raise Base by (Index * 1mm) in Z
      LIN StartPoint
      ; torch on
      LIN EndPoint
      ; torch off
      LIN Escape ; move clear of weld
    ENDFOR
  • potibo83
    Guest
    • March 8, 2016 at 2:34 PM
    thanks to both of you. It works well. but in the ceyhan´s option when i restart the program again P1 and P2 are not in the original hight point. They are positioned at the last point of passage.
    SkyeFire
    1,052
    9,431
    • March 8, 2016 at 4:22 PM
    You have to include a means to "undo" the changes when you start a new part. You'll note that in my example, I set $BASE (a dynamic variable) to BASE_DATA[1] (a static variable), and then perform all my changes to $BASE. BASE_DATA[1] is never tampered with, and as such always serves as the initial start point for a fresh part.
