Does anyone have a wordfile for Fanuc TP programming that I could load into ultraedit for offline programming? (.uew file extension)
Ultraedit wordfile for Fanuc TP programming
spreenpe47 -
February 11, 2016 at 9:00 PM -
Sure, just unzip the attached. This is from v17 of UltraEdit. v18+ have issues connecting via ftp to the Fanuc, which is why I have yet to upgrade.
Thanks Nation!!
You are the best ! thanks
Hello! can somebody explain me how to add this .euw to my ultraedit? as far as i can see it only accepts .txt files...
Thanks in advance!
Thanks in advance!
You must paste the file in C:\Users\xxxx\AppData\Roaming\IDMComp\UltraEdit\wordfiles
Regards
You must paste the file in C:\Users\xxxx\AppData\Roaming\IDMComp\UltraEdit\wordfiles"
I pasted it in the wordfiles folder and restarted, but it does not show as one of the choices in the drop down. Did I miss something?
Don't know it really for ultra edit, but on other software the path you have to copy depends on installation method. The path varies if you install it 'only for actual user' or 'for all users'. Sometimes you have to copy such files to the program folder.
I now have the Fanuc .tp available in my Highlighting drop down menu (under the coding tab). It does not have any effect on the .tp program that I load from a USB drive, it reverts back to No Highhlighting Selected. I want make program changes offline and the reload back into the robot, without ASCII Uploader. What am I not doing?
II want make program changes offline and the reload back into the robot, without ASCII Uploader. What am I not doing?
You can't.
At least You can't edit .tp files with a regular text editor.
.tp files must be changed on Roboguide or on robot itself.
You can't ...
... because TP-files are compiled code and thus it can not be edited. You have to save the TP-programs as LS-files to USB-device at the cabinet or import it from the FANUC to RoboGuide and save as LS there.
