Can anybody please tell me how w, p and r angle can be calculated at a point???
Calculate w, p and r
- sachincool786
What do you mean exactly by "how can they be calculated" ? What are you trying to achieve ?
just for the info, like x, y and z are i can understand.
But i am not able to imagine how w, p and r are coming
w, p and r represent rotations around x, y and z axis respectively.
So this values represent orientation of the tool around axis of a frame. -
a little brief please!!!!
a little brief please!!!!W,P,R
ya[W] [P]itch [R]otation
Starting with rotation, since it,s the easiest to understand. That is which way the tool is rotated. Pretend it's a clock.
Yaw and Pitch are just two different tilts. Looks up pitch and yaw on an airplane and I'm sure you'll find some explanations.
As far as calculating goes, I normally don't mess with Yaw and Pitch besides when I first teach the point. I have never automated any math with them.
How can i physically feel them???
i mean to say how can i calculate them??
If my robot is at some point , how can i say w, p, r would be this much without seeing TP -
You would have to look at your tool and know which direction the x,y,z is in your user frame is and what tool frame you are using that the point is taught in. then you would look at your tool and be able to guestimate based off from how the tool is rotated around W,P,R. Which W is the rotation around X. P is the rotation around Y. R is the rotation around Z.
Now if it is a PR I believe it would be the same thing but around the World Frame instead of the user frame.
