Alarm 0021 Communication Error(Servo)
  • luicar1187
  • January 27, 2016 at 12:28 AM
  • luicar1187
    21
    Hi All
    I am new with Motoman robots, the company i just started working have a Motoman XRC UP6 they want to setup for trainning playing a while and reading a little bit the manuals the plant give me I could not make it work in the teach pendant screen it shows the followed alarm
    Alarm 0021
    Comunication Error (Servo)
    [50]
    !Turn ON Servo Power
    If a swap my key to edit, the teach button enable and hold the dead man, the servo ON light start blink but the Turn ON servo power still at the bottom of the screen.
    Can anyone give an idea how to fix this alarm.
    Thanks in advanced
    Images
      • 2.17 MB
      • 2,988 × 5,312
      • 44
    Files
    20160126_150817.jpg_thumb 20.14 kB – 101 Downloads
  • robotnao
    15
    • June 12, 2018 at 8:54 AM
    Hello!
    I have the same problem in my robot.
    Kindly, kan you tell me how did you fix the problem?
  • Robodoc
    56
    7
    1,059
    • June 13, 2018 at 11:28 PM
    With the XRC robots there is a servo system power supply. It's always to the left of the servo pack. There should be a green LED lit up on the power supply when the power is on. If the green light is not on check to see if there is 208 volts AC single phase coming into the servo power supply (two black wires on 1CN).
    Robodoc
  • Mr.Park
    • July 5, 2018 at 10:42 AM
    Hello Sir.
    Thanks for your precious answer.
    But i'm afraid that in my case, it also doesn't work.
    When i turn the power on, it will be show the communication error 0021 [ sub code 50 ] with light on the " remote " button.
    I tried to solve the problem lots of time.
    It was failed, please i need your help...
  • anh chung le
    • December 4, 2021 at 10:23 AM
    Vui lòng cho tôi biết bạn đã khắc phục sự cố như thế nào?
    Alarm 0021
    [50]
  • anh chung le
    • December 4, 2021 at 10:32 AM
    ?thumbnail=1
    Hello!
  • Robodoc
    56
    7
    1,059
    • December 4, 2021 at 2:35 PM
    If this only comes up when turn the servo power on, I would check the servo on light. If there is a short in the servo on light, the 24 volts gets pulled down as the servo power comes on and you will get this message.
    Robodoc
  • Robote
    • February 21, 2023 at 10:22 PM
    Hello!
    Can you tell me how did you fix the problem?
  • Robodoc
    56
    7
    1,059
    • February 23, 2023 at 4:41 PM
    To left of the servo pack there is a small power supply for the servo system. There is a green LED labeled 5v. Is this on or off?
    Robodoc
  • RyanRobot
    8
    • February 24, 2023 at 10:19 AM
    Do the following:
    1.) Remove connector CN10 on the
    WRCA01 circuit board and re-insert it
    2.) Remove the terminal connector of
    CN10 on the WRCA01 circuit board
    and re-insert it.
    3.) Remove connector CN05 on the
    XCP01 circuit board and re-insert it
    4.) Is the LED on the
    WRCA01 circuit board lit?
    5.) Remove connector CN50 on WRCA
    circuit board and re-insert it.
    6.) Remove connector 2CN on the
    RCP01AAA unit and re-insert it
    7.) Check the fuse for the
    RCP01AAA unit
    8.) Remove the connector 1CN on the
