Invalid data found on EDS of device Resolver Digital Converter
  • We have Kuka robot "KR6 R900 sixx" and controller "KRC4 compact".
    When we turn on the robot, we get the next messages on the SmartPAD (in order of appearance by time):
    Warning: 05:44:09 AM KSS00099
    Error on reading/writing: SYS-X44
    Error: 05:44:09 AM KSS02858
    Ackn. Stop due to field bus error
    Warning: 05:44:09 AM KSS15054
    Workspace monitoring functions deactivated (mastering error)
    Infomation: 05:44:09 AM KSS01008
    Cold start of controller
    Warning: 05:44:09 AM KSS00106
    Perform mastering A1
    Perform mastering A2
    Perform mastering A3
    Perform mastering A4
    Perform mastering A5
    Perform mastering A6
    Error: 05:44:10 AM KSS25004
    Converter (RDC) ECAT-CTRLBU (error 0xd8112221)
    Caused by: Drive
    Error: 05:44:10 AM KSS25005
    EDS of device Resolver Digital Converter (RDC) ECAT-
    CTRLBU is empty. No mastering data available (error
    0xd8412280)
    Caused by: Drive
    Error: 05:44:11 AM KSS25004
    Caused by: Drive
    Converter (RDC) ECAT-CTRLBU (error 0xd8112322)
    Caused by: Drive
    Warning: 05:44:19 AM KSS13012
    <SYS-X44> Error during ECat stack initialization [NetworkResponse
    () no Network Response]
    Can you advice to us, what can we to do to fixup the problem.
    Edited once, last by codeman ().
  • always read error messages in order they appear (look at the time stamp, oldest message is on the BOTTOM of message list).
    many other messages are often just result of one original message. for example if controller could not start EtherCat communication, you will get ton of (maybe distracting) messages about things that don't work, which is true but - first you need to fix the communication (KSS13012).
    make sure robot is connected to controller (data cable X21-X31) and even before that, check if pins are bent or pushed out.
  • Thank you, panic mode for the reply.
    I checked data cable X21-31 and pins. Connection is ok.
    Yes, I read messages in order they appear (from bottom to top on the SmartPAD). Message list in my post has reverse order in comparison with SmartPAD.
    So, the first messages (by time) are:
    The last messages (by time) are:
    Caused by: Drive
    I added time stamp to the messages of my list (see the first post).
    I see new two messages on the SmartPAD, that replace each other repeatadly
    Warning KSS 25003
    EDS of device Resolver Digital Converter (RDC) ECAT-CTRLBU
    cannot be found (error 0x48112020)
    Caused by: Drive
    Warning KSS 25002
    Hardware defect detected while writing the EDS of device Resolver
    Digital Converter (RDC) ECAT-CTRLBU (error 0x48012002)
    Caused by: Drive
    What can I to do to fixup the problem now?
  • it could be many things:
    1. RDC
    2. EDS at the RDC
    3. Data cable (X21-X31) or mating ends/cables
    4. CCU (HW or FW)
    5. WoV project (wrong topology for example)
    6. wrong FSoE address or RDC not connected correctly
    etc.
