I would like to point automatically the pointer on the main module, with a button, a digital input or something else.
Does anybody know how can I do plz (by configuration, rapid code or something else)?
Thanks ahead
Thanks ahead
Hi!
You can do it with programmable button. Go to Control Panel -> ProgKeys ->Choose Key. Then choose Type: System, Key pressed: Move PP to Main.
After that, after pressing desired button, your pointer will go to the main module.
Solution works on IRC 5.
Thaankkss !!!
Where are these written? Do you have any manual for these?
If I have to move it pp to main by selecting manual and auto switch then?
it goes in the system parameters folder, in the EIO.cfg file.
Thank you. Actually I recently asked the similar question in different thread. When I switch the key to Manual to Auto, it goes to Automatic.
For program test reason, I want to switch it off. I am attaching EIO.cfg file. Please help me find the location where it mentioned switch to Auto.
Sorry yasirkhi, I don't understand the question. Can you please explain?
When I switch from manual to Auto, the Main program is called directly.
Sent from my Passport using Tapatalk
@ i_ Robot,
Assign a system input with any of your digital inputs and connect a push button on the particular Input.
If push button was pressed it will take the program pointer to main.
Yasirkhi, are you saying that you WANT it to go to the Main program directly, or are you saying that it currently goes to Main program directly and you DON'T want it to?
If I don't want to go to Main when toggle the switch.
Refer to the linked conversation. This fixes that. But be careful, you are turning off all the following features when you change the setting.
- The Program Pointer (PP) is set to Main module for all tasks if callchain does
not originate from Main routine.
- All tasks are enabled.
- All stopped background tasks are started.
- Simulation of all simulated I/O signals is removed.
- Speed is set to 100%.
- RAPID Spy is deactivated.
- PROFIenergy device gets reset.
Sorry but the automatic mail information did not worked !
So i would like to thank you all for your answer. I am going to test that.
Have a good day !
