  5. Manuals, Software and Tools for Fanuc Robots (you should look here first before posting)
A website: Know FANUC alarm codes
  • linuxsand
  • October 20, 2015 at 12:30 PM
  • linuxsand
    21
    40
    http://linuxsand.info/fanuc/
    Hi, I made the website for searching alarm codes of FANUC robots. Webpage is optimized for mobile browser.
    Usage:
    1. normal way: input alarm code, hit "search" button, you'll get the description, cause and remedy.
    2. command line: curl http://linuxsand.info/fanuc/code-api/INTP-440
    Drop me an email if website is down: root {at} linuxsand {dot} info
    http://linuxsand.info/fanuc_tools/
    Edited 5 times, last by linuxsand (March 21, 2022 at 3:42 AM).
  • dmbj
    14
    202
    • October 20, 2015 at 1:43 PM
    Super cool.
    Bookmarked.
  • Jonson
    211
    • October 21, 2015 at 1:20 AM
    That's so good!
  • amy_fields
    26
    • October 22, 2015 at 2:54 AM
    Sweet! Good Job. Bookmarked
  • Tobi
    8
    • October 22, 2015 at 3:14 PM
    Awesome!!
    Will be used a lot.
  • robcad
    • October 25, 2015 at 10:17 PM
    linuxsand Good Job
    :merci:
  • swapnil
    38
    • October 27, 2015 at 11:37 AM
    what a nicee Site.
    Tons of Thanks linuxsand
    Bookmarked.
    All power is within you; you can do anything and everything. Believe in that; do not believe that you are weak; do not believe that you are half-crazy lunatic, as most of us believe now-a-days. You can do anything and everything, without even the guidance of any one. All power is there. Stand up and express the divinity within you--Swami Vivekananda
  • Matic123
    • December 10, 2015 at 1:45 PM
    :guru:
    Two things are infinite: the universe and human stupidity, and I’m not sure about the universe!
  • Skogsmulle
    Guest
    • December 11, 2015 at 10:31 AM
    Thank you!
  • Nation
    Typical Robot Error
    547
    1,925
    • December 11, 2015 at 6:43 PM
    We should sticky this thread. Very useful.
    Edit: Hey it got stickied! Sweet.
    Edited once, last by Nation (December 14, 2015 at 3:08 PM).
  • irobot
    271
    • December 17, 2015 at 3:24 AM
    • #11
    good job
    KUKA Conntroller : _________<br />KSS Software : ____________ <br />Robot Model: _____________
  • Iprogram
    148
    • January 15, 2016 at 6:18 PM
    • #12
    How is this different than pushing the shift key and DIAG at the same time?
  • linuxsand
    21
    40
    • January 16, 2016 at 4:40 AM
    • #13
    Quote from Iprogram
    I extracted contents from manual (Alarm codes list of R-30iB, B-83284EN-1/02) , which includes more info, i.e. cause & remedy.
    I have no idea if Fanuc teach pendant had those built-in info.
  • Nation
    Typical Robot Error
    547
    1,925
    • January 16, 2016 at 2:50 PM
    • #14
    Quote from linuxsand
    They do, but I have found that the remedies in the diag area of teach pendant tend to lag behind what is in the manual. Other times the fault simply won't be in the diag area, but it will be in manual.
    Quote from Iprogram
    See above.
  • trader
    16
    • February 10, 2016 at 2:24 AM
    • #15
    VERY NICE.. Thank you..
  • robotatwork
    29
    • February 20, 2016 at 5:05 AM
    • #16
    Thank you Linux
    :respect:
  • tangquach
    • March 23, 2016 at 2:20 PM
    • #17
    Supper! Thank you Linux
  • Kosy
    15
    • July 20, 2016 at 1:19 PM
    • #18
    :respect:
  • zanybu
    Guest
    • July 27, 2016 at 10:28 AM
    • #19
    thank you very much :merci:
  • Dean
    33
    • September 6, 2016 at 4:13 PM
    • #20
    how do i turn on the input to get rid of the "IMSTP" ERROR ? from what i have read I go to I/O, select the "type" , then selest "UOP" however i am not geting "UOP" option. the only options I get are "Digital/Group/Robot" am i doing something wrong? any advice?
