hi , good work to everyone. I want to robot control with s4c+ serial port but I don't know where I'll start.
Is this possible, robot movement with mause or anything?
How do I make this project?
- yunusdereli
I'm sorry, but I don't understand the question. Are you saying you want to control the robot movement with a mouse, over a serial connection?
I'm sorry, but I don't understand the question. Are you saying you want to control the robot movement with a mouse, over a serial connection?yes it is.
For the first , you should know how to communicate with robot using RS232-C Standard. And the, you can send pose data to robot and let the robot move along the path which you have planed! FYI. Good luck!
Thanks Jonson, I had no idea how to even start answering that question!
You are welcome !
I have been trying to communicate with PC using TCP/IP. During these days, once in a while, I know some thing about serial communication. RS232-C Standard uses the DB25 connector. There are 3 Pins which are used to communicate with other serial equipments as follow:
2 TXD
3 RXD
7 GNDYou can check the Technical reference manual--RAPID Instructions, Functions and Data types.Search the key words "serial".
For your information !
