Fanuc RJ2 420 İ F my robot. Depending on the robot I want to run valve 24v .
I sent a picture of the socket turns without following any adjustment voltage .
RO / RI using settings you want to check in 24v valve program. I did a lot of research on the subject,
and yet I could not reach any conclusion . How do I need to contact?
Does the need for an external 24v power supply ? Please help craftsmen
1-5-12=+24V 2-3-6-7-9=0V
RJ2 RO/RI PROBLEM
byrol -
August 21, 2015 at 4:50 PM -
Thread is Resolved
There is no need to use external 24v for RO/RI, get the EE connector for the specific robot and reffer the pin configuration do the wiring that's it
Sent from my C2305 using Tapatalk
vipinpunneri
Thank you for your attention. Cabling, and it can pin rank a little more explanation about the settings to be done ?
