Change Configuration of a PR[] in Program
  • joaofidalgo
  • August 4, 2015 at 2:49 PM
  • joaofidalgo
    Guest
    Hi guys,
    Hi need change a configuration of joints in a program, like we can make PR[10,4]=10; something like that but i can´t find information how I can change CONF: NUT to FUT in program... I kown i can chage it in TP when I define PR[]... But I need kown if it possible change it by program language!
    Thank´s in advance :)!
    Images
      • 106.34 kB
      • 678 × 472
      • 45
      • 101.82 kB
      • 676 × 457
      • 40
    Files
    FDB.jpg_thumb 21.45 kB – 638 Downloads NUT.jpg_thumb 21.6 kB – 631 Downloads
  • HawkME
    568
    3,268
    • August 4, 2015 at 4:06 PM
    Create some setup PR's of all zeros for each config you want. Then set your PR = that setup PR in your program, and modify as needed.
    It is not a direct method but works. I also recommend having one set up as joint representation.
    Sent from my VS985 4G using Tapatalk
  • joaofidalgo
    Guest
    • August 4, 2015 at 5:18 PM
    Hi HawkME,
    That is what im doing now, the problem is when you load a program to a new robot you need to configure that points in robot... I want do it in program...
  • Nation
    Typical Robot Error
    547
    1,925
    • August 4, 2015 at 5:53 PM
    You can also assign PRs to points in a program (e.g. PR[100]=P[1]), so you could make a program with some dummy points in it with different configurations.
  • vipinpunneri
    137
    • August 5, 2015 at 3:02 AM
    You can change the joint configuration. Goto edit and move the cursor to P[] then select position press F5 for joint and Cartesian options. Select Cartesian then press config.
    Thanks regards<br />Vipin..
  • zhaoxiang chen
    43
    • October 27, 2020 at 11:05 AM
    hi joaofidalgo,
    i met similar issue recently, thus would like to know if you have found better solution for that?
  • Famous_Fella
    25
    131
    • October 30, 2020 at 10:43 AM
    in a PR the first 6 data are X, Y, Z, w, p, r the 7th data is the position config which is not directly accessible with TP language, nor by inderect addressing (PR[2,7] = [PR1,7]) but only with the use of Karel routine which doesn't really worth the effort. The best way is to make a point in the config you want and copy it in the PR before loading each of the 6 values of positions (XYZwpr).
  • Sangito
    • November 3, 2020 at 2:48 PM
    Soo Far i use the Karel to initiate a config var like in the manual, but I didin't find how to push it on a XYZWPR var.
    I think i will be in obligation to translate into a position data type to use it.
    VAR
    config_var1, config_var2: CONFIG
    pos_var: POSITION
    seam_path: PATH
    i: INTEGER
    BEGIN
    config_var1 = pos_var.config_data
    config_var1 = config_var2
    config_var1.cfg_turn_no1 = 0
    IF pos_var.config_data.cfg_flip THEN...
    FOR i = 1 TO PATH_LEN(seam_path) DO
    seam_path[i].node_pos.config_data = config_var1
    ENDFOR
    In hope it will help you.
