Anyone know if there is a system variable that controls the mode of the "Force Message" item under system->config? I am trying to write a setup routine and want to turn that off from the default of on.
Force Message System Variable
- Nation
Try $AUTOMESSAGE, I found the following information in a variable list document.
$AUTOMESSAGE
Minimum: 1 Default: 2 Maximum: 3
KCL/Data: RW Program: RW GET/SET_VAR: RW Data Type: INTEGER
Name: AUTO MESSAGE TYPE
Description:
1 : The "force user screen message function" is disabled.
2 : (Default) The "force user screen message function" is enabled.
3 : The "force user screen message function" is enabled only when the teach pendant is disabled.
Others : As same as 1.
Power Up: Changes to this variable take effect immediately.
User Interface Location: SYSTEM variable screen and SYSTEM configuration screen (on the teach pendant) -
Sweet that works. Of course that variable is not in the current gen of the Fanuc documentation.
Dave, what document did you quote?
It was from a "2.2 SYSTEM VARIABLE LISTING" Unfortunately I don't know where my colleague got it from. Someone emailed the document to him. I can forward it if you like. It is an older one that doesn't have all the variables.
Yes, please forward it to the email in my profile.
I would be interested in it as well.
It was from a "2.2 SYSTEM VARIABLE LISTING" Unfortunately I don't know where my colleague got it from. Someone emailed the document to him. I can forward it if you like. It is an older one that doesn't have all the variables.Please send it to me also. Thanks.
It was from a "2.2 SYSTEM VARIABLE LISTING" Unfortunately I don't know where my colleague got it from. Someone emailed the document to him. I can forward it if you like. It is an older one that doesn't have all the variables.Hi Dave
please can you send me also? thank you
I uploaded the variable list to Box.com so people can have easier access. Follow the link below to download the list.
https://app.box.com/s/za87zp035lnfolgpn5xfniu3uwkgawit
The PDF file is the newest list. You can find this in the HandlingTool documentation. It is listed in the Reference section using the Software Reference Manual link.
