I'm working on the pick-drop application using M-710iC robot and R-30iB controller. Now I dicsovered interesting problem.
I use two of user frames. One user frame is used for part picking and another is for part droping. If the user frames are switched during the movement, robot jerks. It looks like shock, probably the robot stops immediately in the middle of movement and starts again without ramps.
Is it possible? Is it normal? How is the proper way to switch the user frames?
Thank You for any suggestion.
