Hello everyone
I want to implement seam tracking with laser sensor on ABB, but i don't know which software package i need to setup and which hardware i need to add to the controller.Is there any tops or manuals i can reference?
Thanks!!
Which software package i need to implement laser tracking?
- Jonson
Call your ABB region sales rep, I'm sure they would be more than happy to help you
Um-Hum, you are right. But the laser sensor is mine, i don't know whether they will help me. I want to take an early look at some doucuments or topics to know what i need specificly. Thank you!
Now, i've found some ABB's Options, such as Path Offset, PC Interface, Sensor Interface, Externally Guide Motion. But i don't know which one i need, who can tell me, which one can be used to connect my sensor? I think maybe it's a universal interface which can also connect to Servo Robot or Meta!
You can install:
1. If you use the sensor with Arc welding commands.
660-1 Optical Tracking Arc
Integration of Tracking functionality into RW Arc.Or
2. If you use own commands.
813-1 Optical Tracking
Integration of Tracking functionality into CAP
628-1 Sensor Interface
Communication interface, LTC* and RAPID instructions
Included in options 660-1 and 813-1.ABB use LTAPP protocol for comunication with a laser traking sensor by RS-232 or Ethernet.
ABB ID of documantation which you need:
3HAC031094-001 Laser Tracker Calibration Interface
3HAC16591-1 Arc and Arc SensorUnfortunately I have not got more opened documets.
If that help you below the description of LTAPP for the Scansonic TH6D sensor.ID Variable Description Read / write
1 Version =0 Read
4 Ping Check if sensor ready Write
6 Start Start seam tracking (on = 1, off = 0) Read / write
7 Pause Unused Can only read. (on = 0, off = 1) Read
8 X Measurement data (average of 3 measurements) Read
9 Y Measurement data (average of 3 measurements) Read
10 Z Measurement data (average of 3 measurements) Read
11 Gap width Measured data Read
12 Step height Measured data Read
13 Surfaces Measured data Read
16 Seam ID Seam number Read / write
17 Time Time stamp, unsigned word, time difference since the last
request
Read
18 C Measured data Read
19 Unit 0 = 0.1 mm, 1 = 0.01 mm Only valid for Y, Z, gap width and
step height
Read / write
51 B Measured data Read
52 A Measured data Read
53 Flange Column width Read
54 X0 Measured data (from first line) Read
55 Y0 Measured data (from first line) Read
56 Z0 Measured data (from first line) Read
57 X1 Measured data (from second line) Read
58 Y1 Measured data (from second line) Read
59 Z1 Measured data (from second line) Read
60 X2 Measured data (from third line) Read
61 Y2 Measured data (from third line) Read
62 Z2 Measured data (from third line) Read
There is not need any aditional hardware for connect a sensor system to a robots cotroller. -
Thank you very much for your help, i will have a try.
Your replay is so detail that i have clear direction to complete this.
Thank you again!
