reading new line in .txt file
  • jagroop77
  • May 11, 2015 at 2:03 PM
  • jagroop77
    168
    We are trying to read the data from .txt file with karel program.
    at the moment karel program is reading the data from file is the data is seprated by comma or tab .
    But it is not reading the data if the data is written in new line.
    example
    201,303,404..................is working
    201,
    303,
    404
    ...............is not working.
    can someone help me that how to jump to next line to read the data
    Rupy
  • gwallee
    41
    • May 11, 2015 at 11:45 PM
    Are you calling the "READ" command more than once? Each time it is called, a new line is read/
  • urdemiul
    26
    • May 11, 2015 at 11:51 PM
    Hi rupy,
    best way to do it is with one example. My *.txt file is reading an integer and two strings as you can see:
    1002 'Description' 'Comment'
    1003 'Description' 'Comment'
    So the statement READ in the program looks like this:
    REPEAT
    READ Readfile (Num,Descrip::0::2,Coment::0::2)
    UNTIL STATUS<>0
    Using the loop allows to read the next line until a new end of line is found. As you can see there are no tabs only spaces and remember to do the formatting of the data you want to read in order to extract the content from the *.txt file.
  • jagroop77
    168
    • May 12, 2015 at 6:38 AM
    thanks for your help.it is working .
    I have used the read command one more time and it is working
    thanks
    Rupy
  • dha
    28
    397
    • February 16, 2016 at 11:01 AM
    I'm having trouble reading txt file.
    I need to read only the first line of text file. I'm getting error 2021 if line is shorter or longer than 10 characters.
    PROGRAM READER
    	%NOLOCKGROUP
    VAR
    	f_file		: FILE
    	s_code		: STRING[10]
    	i_code		: INTEGER
    	STATUS	: INTEGER
    BEGIN
    	s_code = ''
    	i_code = 0
    	--SET_FILE_ATR (f_file, ATR_UF)
    	-- Opening file
    	WRITE ('', CR)
    	WRITE ('', CR)
    	WRITE ('Opening ...', CR)
    	OPEN FILE f_file ('ro', 'MC:test.txt')
    	STATUS = IO_STATUS (f_file)
    	IF STATUS <> 0 THEN
    		WRITE ('Open status: ', STATUS, CR)
    	ENDIF
    	-- Writing to file
    	--WRITE f_datoteka ('This is line 1', CR)
    	-- Reading from file
    	WRITE ('Reading ...', CR)
    	READ f_file (s_code::10)
    	--READ f_file (i_code)
    	IF STATUS <> 0 THEN
    		WRITE ('Read status: ', STATUS, CR)
    	ENDIF
    	-- Writing code
    	WRITE ('Code: ', s_code, CR)
    	--WRITE ('Code: ', i_code, CR)
    	CLOSE FILE f_file
    END READER
    Even if I use READ f_file (s_code) instead of READ f_file (s_code::10) I'm getting an error: Uninitialised data used ...
    As I understand manual, READ should return string even if it is shorter than specified and truncate if it is longer...
    What am I doing wrong?
