Hello everyone,
I want to use PNS option to start a program from outside, I set the system for this, I read that the PROD_START is the signal used to start the program selected, but this option is not available on my screen! Those are the options that I can see for the UOP:
U01 OFF Cmd Enabled
U06 ON Fault
U09 OFF Batt alarm
U010 OFF Busy
UI 1 ON *IMSTP
UI 2 OFF *Hold
UI 3 On *SFSPD
UI 4 OFF Cycle Stop
UI 5 OFF Fault Reset
UI 6 OFF Start
UI 7 *
UI 8 OFF Enable
UI 9 OFF PNS1
UI10 OFF PNS2
UI11 OFF PNS3
UI12 OFF PNS4
UI13 *
UI14 *
UI15 *
UI16 *
UI17 OFF PNS strobe
UI18 *
I found that START (UI6) is used to continue a program which was stooped previously, where is PROD_START? How can I start a program from line 1?, Is there any way to use PNS5 .... PNS8?, I'm using a RJ3iB- Mate controller.
Regards.
