Hi!
I use KRC4 and I tied to use DirLoader to copy files from USB. I think all configuration of DirLoader is ok.
I got Error:
Directory Loader 2
Invalid program statusStop
What is the reason? How to overcome it?
Hi!
I got Error:
Directory Loader 2
Hi Mikail
What is the reason to use Dir Loader if you still use an USB for transfering src files from PC to robot?
What is the role of Dir Loader. I am interested too in this matter.
USB was used only for test. I need to transfer files from external PC to KRC.
Not sure if USB works. Try it on the local hard drive in an exchange folder first.
yes, I tried to copy from local disk D:\\directoryloader\. I got same error.
What is "StatusStop"? Is that the name of a program you're trying to transfer?
Have you checked all the programs you are trying to load for compilation errors?
