krc1a error? and mouse issue
  • rgtxa
  • April 10, 2015 at 7:03 PM
  • rgtxa
    29
    Does anyone know what causes the attached error on a krc1a?
    Also is it possible to get a mouse to work with this control? I have tried the port at the control and pendant. A keyboard will work but not a mouse.
    Images
      • 1.7 MB
      • 3,264 × 1,836
      • 40
    Files
    IMG_20150409_163856_888.jpg_thumb 23.66 kB – 10 Downloads
  • Florida
    103
    • April 10, 2015 at 8:10 PM
    Most of the time you see an error like this is when something is wrong with the MFC or files in your system are corrupted. Eventually try to run something like scandisk. If that comes back with errors, I would say your files are corrupted. Otherwise I would check/replace the MFC card.
  • rgtxa
    29
    • April 10, 2015 at 9:15 PM
    I have swapped out the MFC card and reloaded the software.
  • Florida
    103
    • April 11, 2015 at 1:44 PM
    Is it working now?
  • rgtxa
    29
    • April 11, 2015 at 3:14 PM
    No. It is the same.
  • Florida
    103
    • April 11, 2015 at 6:25 PM
    OK. The message shows "no shared memory driver yet installed". I don't know how you reinstalled the software but check under Network settings if you have an active connection to 192.0.1.2
    If you just did a KRC Reinstallation or a regular Windows installation without KIS it maybe doesn't work.
  • rgtxa
    29
    • April 12, 2015 at 6:10 PM
    I did not see that connection in network settings. I did not see any type of KIS.exe. How do I run/install that KIS? Thanks
  • Florida
    103
    • April 13, 2015 at 1:41 PM
    KIS is a KUKA installation disk. If you don't have a directory KIS somewhere you're lost. Try to reinstall to another Hard drive using the KUKA CD including Windows. Hopefully that installs the shared memory driver. Or if possible image another running system to your system and install the required KUKA KSS.
    Without the Shared memory driver 192.0.1.2 your system won't work! :icon_frown:
