Hi .
i am having KRC4, KR90
I am getting this notification:
basic inspection due
and red light on the panel start blinking.
how can i solve it?
Please help
Hi .
how can i solve it?
Please help
I happened to met this message ,but I have not found the reason. so this time , I search the forum and find some threads about it:
https://www.robot-forum.com/robotforum/kuk…48139/#msg48139
https://www.robot-forum.com/robotforum/kuk…68943/#msg68943
the first red light on CSP flashes when scheduled inspection reminder message is displayed.
you can still use robot but you should have mentioned service done.
basic inspection includes overall appearance check, running noise check, mastering check, fouling/leakage check, fan check etc.......
panic mode,
which doc introduce the maintenance content ?
update: the system integrator chapter 5.13 found
How old is the robot is the service actually due ? , i have seen some that show service due after only 2 months.
Maybe due to the date not being reset when they installed the image of the controller ?
You can do this to remove the message
Startup\ service\maintenance Handbook
then fill out the service its looking for " basic inspection " you have to put something in every field
Then press save when you exit this you might get a message saying error this is normal if before you exit you can look to the overview tab you will see your entry
just so you know, whatever you enter will stay... don't try to get funny ...
