Hi Guys,
I am having problem configuring a profibus master on DX100 and need some help.
I am using Nettool demo for Profibus as I have only two slave devices. I took a 9 pole serial plug and soldered red and green on 3 and 8 respectively. Shielding is also connected to the serial plug housing. This profibus cable is connected to a slave which has termination on its output.
For configuration, I connected the usb adapter using a null modem adapter and tried to scan the network, I got an error "Can't create transport path" and when I connected without null modem adapter, i got a network scan window with no devices on it. All was tried in Maintenence Mode. I have a DeviceNet Master card in the first slot, to which i can connect and configure without any problem. I used the default gsd file which came with the nettool.
Can someone tell me what could be wrong?
