Hi everyone,
I have RobCad 7.5 that this one worked on the windows XP,
Now I changed my Windows to Windows 7 ultimate,
But my Robcad can not work,
some one can help me?
Thanks a lot.
Hi everyone,
Thanks a lot.
The oldest version of Robcad I have used on Windows 7 is 9.0, so im not sure of 7.5 working, but your best chance would be to install the latest patch off the siemens portal.
Thanks for answer,
But, my robcad there's no licence, work with "crack"
I'll try to find other way,
Thanks a lot.
First of all that is very naughty of you to work with a crack.
The problem is exceed.
If you used the exceed of 7.5 that will not work on windows 7.
You need a higher version of exceed that can operate with w7. That's why there were no problems with Robcad 9
We had a customer who wanted ab older version of robcad so we installed the exceed of V9 and then installed 7.5 without exceed.
Is it possible torun Robcad V9.0 on Windows 10 with Exceed 2008 SP11?
1. win7 32位可用安装robcad7.5 win7 64位没办法安装
2.Rrobcad9.0/9.0.1/9.1/11 其中 9.0/9.0.1/9.1是可用安装win7 64位 win10 部分版本可用安装。robcad11可用安装win10任何版本。
希望对你有帮助
Yes it's possible to run Robcad V 9.0 on Windows 10 , but the latest update must be Windows 10 Creators update, if you have a newer version of Windows you'll get an error and have to reinstall the OS again. See the most common error attached below for this problem.
