Question for you folks...
Is there a way to force the simulation in MotoSIM EG-VRC to run in realtime? I would like to make the controllers keep time with reality so that what is seen on the screen is the same as what would occur on the production floor.
I can get it close by adjusting the settings under the Heart Beat icon, refresh interval settings window, but would like it to be more accurate.
Any ideas?
Thank you for your attention!
MotoSIM In Real Time
mitchman724 -
March 18, 2015 at 3:16 PM -
Thread is Resolved
When you write "more accurate", what are you expecting ? tens of a second ? seconds ?
What length of cycle time are you questioning about ?Normally what I do, I program a 10 second timer and then I adjust the heart beat until I obtain 10 seconds in real life
Hello everybody
I take this thread to point again. I read the Motosim Manual (Chapter 9 - Online Function) to go online and monitoring.
I'm using a DX200. I follow the steps of the chapter 9.
Status: I can connect with the "Network Function" and move the robot from MotoSim and also can manage files with "File Manager" (transfer .JBI from PLC/MotoSim to Real Controller)
Need: to see in my Virtual Pendant what is going on in my real/physical pendant
E.g., if I press the emergency stop in my physical pendant this get replicated in the virtual pendant.
Or if I get IN#(5) ON, to be able to see it on the virtual pendant.
Is this possible?
Thanks in advance -
when your robot is connected, the position of your virtual robot is updated in realtime. There is not possible to run a program in reality from virtual pendant.
However the current task is displayed on a Simple PP.
Thanks for your answer
Yes, I was able to run that. It's useful.
I was able to check that too.
This is what I need. Mostly because I want to check some data in the Register (I'm communicanting via ethernet to a PLC).
I see that YRC100micro has a Remote Programming Pendant option and I was hoping that or something like that was featured in DX200.
I don´t think that exist this option on the generation DX200. This option is available only YRC1000 or YRC 1000 micro
I've tested the robot manager on YRC1000, but I think that it works on DX200. Robot ma ager shows the position in program and also can mo itor IO and variables.
