Hello, I am working on a project in which a new software is to be installed. Since this file is neither being shown in available software nor in new software. So i try configuration of that file, even then the file is not being displayed on teach pendant.What to do??
Some say that for installing a software, it is to be run in the Windows interface.Is it true??I I am using a touchscreen teach pendant. I couldn't find Ctrl+Esc on that touch pendant which is to be generally used for previous version of teach pendant.
KRC4
- bharatsikka
If you need to install software option, there is a menu option.
If you want to go to windows log expert, go startup, service, there should be option minimize HMI. -
your robot was delivered with set of documentation (disc called "Parts & Docs"), which contains everything you need to know. put the disc into your computer, run included software, navigate to Documentation>KSS>System Manual>System Integrator
read chapter on software installation, specifically installing additional software.
btw same documentation is also available on the smartPad itself... just click on Menu>Help>Documentation
