where is the "message database" of KRC4 ?
  • irobot
  • December 18, 2014 at 3:01 AM
  • irobot
    271
    Hi
    I am looking for the muli-language message programming. I found a little information about it
    KSS_82_messages_en
    Type: KrlMsgParType_T
    Type of button label
      • #value: sk_txt[ ] corresponds to the button label.
      • #key: sk_txt[ ] is the database key containing the label
        of the button.
      • #empty: The button is not assigned.
    but which file is the database file ? :hmmm:
    KUKA Conntroller : _________<br />KSS Software : ____________ <br />Robot Model: _____________
    Edited once, last by irobot (December 18, 2014 at 3:10 AM).
  • panic mode
    1,263
    13,030
    • December 18, 2014 at 3:38 AM
    if I recall, it used to be database called kuka_tab.mdb but now (KSS8.3) it is a KXR file (XML file with extension changed).
  • irobot
    271
    • December 18, 2014 at 6:31 AM
    thanks! I finished the mult-lanuage message programming! :cheer:
  • panic mode
    1,263
    13,030
    • December 20, 2014 at 5:39 PM
    :beerchug:
  • irobot
    271
    • October 10, 2017 at 5:58 AM
    somebody PM me about the usage about Multi-language
    the fast way is open a OPT setup folder , you will find some kxr files, these will be install to the KRC4 controller C:\KRC\DATA , open them , you will find the way.
