How to compare strings?
  • x9tech
  • November 14, 2014 at 1:46 AM
  • x9tech
    99
    I have a string variable STRIN[100] that is accepting string input from an external source...
    I want to process this via a few IF statements and react accordingly.
    How would I compare to see if STRIN[] == OTHER_STR[] ?
    panic mode
    1,294
    13,126
    • November 14, 2014 at 2:08 AM
    use STRCOMP() or use loop to check the strings yourself (char by char) :icon_wink:
  • x9tech
    99
    • November 14, 2014 at 3:26 AM
    I get a 'Name not declared as function' when trying to use STRCOMP(STRIN[],"TEST")... is this an add-on function?
  • Fubini
    282
    1,903
    • November 14, 2014 at 6:12 AM
    No its available since quite some time:
    BOOL StrComp (CHAR strComp1[470] :IN, CHAR strComp2[470] :IN, CASE_SENSE_T CaseSens :IN)
    strComp1 string to compare with strComp2
    strComp2 string to compare with strComp1
    CaseSens case sensitive or not (#CASE_SENS, #NOT_CASE_SENS)
    return value Returns TRUE if the strings are equal
    The following simple test worked fine for me
    bool result
    result = StrComp ("ABC”, "ABC”, (#CASE_SENS)) 
    result = StrComp ("ABC”, "abc”, (#NOT_CASE_SENS))
    result = StrComp ("ABC”, "abc”, (#CASE_SENS))
    result = StrComp ("ABC”, "acb”, (#NOT_CASE_SENS))
    Did you assign your result to a boolean?
    Fubini
  • AdrianoD
    • January 26, 2023 at 9:44 AM
    Hallo ,Ich Habe eine KRC1 V4.1.7 SP5, und versuche gerade Strings zu vergleichen.
    Bin noch Anfänger habe die RS232 über com2 am laufen und möchte darüber strings vergleichen.
    Fehlermeldung Name nicht als Funktion vereinbart kommt wenn ich das schreibe
    IF StrComp (RX_Buffer[],RX_BUFFER_SOLL[],#CASE_SENS)==TRUE THEN
    Was mus ich denn genau declarieren um die Funktion ans laufen zu bekommen?
    Habe StrComp als BOOL schon versucht.
    panic mode
    1,294
    13,126
    • January 26, 2023 at 4:35 PM
    please use English in this forum.
    that KSS is too old and does not have string functions, ON_ERROR_PROCEED, $ERR etc.
    this means you need to use a workaround such as external function or using fixed length strings where you specify the max length to compare.
    example comparing first 3 characters (match):
    example comparing 5 characters (mismatch):
    not sure how to check string length in so old KSS so your strings may need to be padded with spaces
Users Viewing This Thread
  • 1 Guest
