Read the rules of the forum regarding Yaskawa You should not be asking for FD parameters
As far as the SxC parameters, some of them are available to you in the Manual. Did you get any CD when the got the robot ? they are there.
As far as the commands, I'm not sure if this is the answer but you could check in the menus, You will find a menu that shows a lot of options, one of the is Language Be sure that is on Extended
