Hi, First let me introduce myself my name is hugo galarza, i´m from mexico and im new in all of this industrial robots topic.
Recently i started working with fanuc robots in my job. Im working with a "LRmate200iC" robot with a "R30iAMate" Controller. The robot is sharing data with a PLC Allen Bradley L27ERM-QBFC1B, by the TCP/IP protocol with ethernet wire. When i finished the configuration of the protocol, a message appeared in the teach pendant display; "PRIO-230 Ethener/Ip Adapter Error". the most weird of all of this is when I entered to I/O display, into the section of UOP signals, all of signals had a weird behavior. They turn on and off when they should not do.
example:
I have the controller in mode T1 and i´m not running a program but the signal of program running is "ON"
When i start running a program, the signal turn on and off intermittently
and this happens with many signals such as " CMD enable", "Busy","Fault, "Snack", "Battery".
Can anybody help me in this situation?
What do i need to do?
How Can i Fix this problem?
