hello,
does anybody know a variable to know if the robot is inside a safe operation zone? They told me to use $sr_range[number] But doesn't exist...
thank you so much
p.s. Sorry for the title error but I can't modify it
hello,
thank you so much
On KRC4 the bitfield $SR_RANGE_OK[] should do the trick. In KRC2 you have the signals $SR_RANGE1_OK, ..., $SR_RANGE8_OK inside STEU/$machine.dat.
Fubini
wow thank you...But i've tryied in KRC4 and seems to remain always in TRUE state..
Do you have Safe operation installed? Or did you use the unsafe workspaces $workspace? Are your safe zones active, see $sr_range_active[]?
Fubini
Yes safe operation active But $sr_range_ok[] tell me if the zone is violated not if the robot is inside (with "by input" robot can be inside a zone While is not violating it, in this case $sr_range_ok remains always True)
