Getting VR offsets to registers?
  • kmcgregor
  • October 27, 2014 at 11:12 AM
  • kmcgregor
    35
    I had a problem the other day with my vision application. The GPM locator put my robot about an inch off of where it should have been. My fixturing is pretty solid, I should never be offset by more than 5mm.
    I want to run a "sanity check" program where I look at how far the VR offsets are, and if they are more than 'X' amount then I will flag an alarm saying something is going on.
    I was hoping to do this by having a command like the R[1] = VR[i,j]... like I can do with a position register, then I can use the info in the registers to compare. The problem is that I haven't found an instruction to get the VR offset values.
    Anyone have any idea on how I could get the offset data into a register?
  • Racermike123
    14
    901
    • October 27, 2014 at 11:56 AM
    Controller model and vision system type??
  • Fabian Munoz
    134
    Articles
    1,517
    • October 27, 2014 at 12:54 PM
    HI
    Under INST, VISION find the command []OFFSET, Select it and you will see
    PR[...]=VR[...].OFFSET
    Then, you can use
    R[xx]=PR[aa,bb] to take apart the position
    Retired but still helping
    Edited once, last by Fabian Munoz (October 27, 2014 at 2:21 PM).
  • kmcgregor
    35
    • October 27, 2014 at 1:47 PM
    That's what I'm looking for. Thank you!
  • Speedy1985
    5
    • October 30, 2014 at 9:55 PM
    You can also use a Limit Check tool. Just look for "application setup Tools" in the Vision Setup.
