In KRL, any SIGNAL variable is inherently a 32-bit signed integer, even if you declare it as smaller than 32 bits. There is no implicit means of putting a Real/Float value onto a SIGNAL.
This is what the IEEE-732 standard is for. You can convert between the "real" floating-point value and an integer binary representation, and most PLCs do this automatically when programmed to send/receive a floating-point value over a bus connection. In KRL, you have to program the conversion yourself. These days, the CAST_TO and CAST_FROM functions work for it, Panic Mode has several examples in the forum archives.
