Dear Members, Does the EMD (electronic mastering device) is a part of standard KUKA QUANTEC robot order? Should I order it in separate? What's the estimated cost?
OK, so it's not a part of the supplied robot, the customer must buy it separately?
you need to understand, if you need to master the robot, its for a reason. it can be the robot got hit from unexpected movement, or motor need to be replaced, or data was erased. the EBD is needed to zero the driver, so the robot will know is location in the world.
if you are a robot solution provider, you need the tool, to make maintenance to the robot, or recover from unexpected move which made the robot lose it's location.
if you are the customer, i suggested to take a kuka collage lessons, part I , to understand what you are doing
mastering tool and USB Recovery Stick are not part of the standard robot order but it is good idea to get them on a same order (together with the robot ) - generally, buying bundled items is cheaper than ordering them separately. talk to your sales guy about any price break...
