Has anyone done a project that recorded speed and torque data in a file (binary or flat file) and send that file to a server?
Any suggestions/help will be highly appreciated.
Thanks,
zell888
Thanks,
zell888
Speed and torque monitor is the basis of the gearbox monitoring function available on the DX100.
What are you wanting to accomplish?
RoboGuru
We want to perform offline analysis on the servo-motor. We will then feed that data file into another software.
The teach pendant oscilloscope function might be what your looking for. You can plot the results to CSV file.
RoboGuru
Thank you for your quick reply. But is there a more automated way to do this? For example, whenever a specific program is run and I need the torque readings and speed to be sent out after each time that program is run?
Zell i also tried to do same thing. The basic function is to use it for maintenance purpose. But what i got to know is that all these data is stored in system variable which is not open to the user.
The teach pendant oscilloscope function might be what your looking for. You can plot the results to CSV file.RoboGuru
Robo Guru
How can I enable this function?
You need to buy it
