Asynchronous speed
  • eusty
  • June 3, 2014 at 8:41 PM
  • eusty
    721
    I've a strange issue with an Asynchronous axis rotating at half speed.
    The issue is intermittent, mostly it runs at exactly half speed, other times at the correct speed when you monitor $VEL_AXIS[?]
    I set $OV_ASYNC in my main loop program, so it's not being overwritten anywhere.
    IF $OV_ASYNC<>?? THEN
    $OV_ASYNC=??
    ENDIF
    The movement command is in the SPS.
    I'm confused as I can't think of anything which would modify the speed, I've mentioned it to Kuka UK and they are stumped too....open to ideas ???
  • panic mode
    1,267
    13,033
    • June 3, 2014 at 9:18 PM
    is the axis permanently asynchronous or you switch back and forth?
    SkyeFire
    1,039
    9,380
    • June 3, 2014 at 11:30 PM
    What about $VEL_EXTAX and $ACC_EXTAX? Are you checking or explicitly controlling them? I've had trouble with that in the past.
  • eusty
    721
    • June 4, 2014 at 6:24 AM
    I'll get them to take a look at it (the system is in the US).
    The axis is permanently asynchronous.
  • eusty
    721
    • July 10, 2014 at 6:33 PM
    Only now got over to the US and indeed it was $VEL_EXTAX which was causing the issue.
    SkyeFire
    1,039
    9,380
    • July 11, 2014 at 9:31 AM
    Thanks for the update.
  • Shubham Jain
    33
    • October 17, 2019 at 7:58 PM
    Quote from eusty
    $OV_ASYNC=??
    ENDIF
    I'm confused as I can't think of anything which would modify the speed, I've mentioned it to Kuka UK and they are stumped too....open to idel
    for which purpose we use $ov_async and when ? :question_mark::question_mark:
    SHUBHAM JAIN
  • panic mode
    1,267
    13,033
    • October 17, 2019 at 8:00 PM
    check manual...
  • Shubham Jain
    33
    • October 17, 2019 at 8:44 PM
    Quote from panic mode
    check manual...
    i am not getting from manual, please tell me :blumen:
    SHUBHAM JAIN
  • panic mode
    1,267
    13,033
    • October 17, 2019 at 8:54 PM
    i cannot help if you don't share what exactly is preventing you to get the info from the manual
    Images
      • 62.48 kB
      • 818 × 555
      • 41
  • Shubham Jain
    33
    • October 17, 2019 at 9:04 PM
    • #11
    DEF turn_0( )
    ;FOLD INI;%{PE}
    ;FOLD BASISTECH INI
    GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
    INTERRUPT ON 3
    BAS (#INITMOV,0 )
    ;ENDFOLD (BASISTECH INI)
    ;FOLD USER INI
    ;Make your modifications here
    ;ENDFOLD (USER INI)
    ;ENDFOLD (INI)
    $async_axis = 'b0001'
    $ov_async = 30 what is the use of this variable??:question_mark::question_mark:
    asyptp {e1 0}
    END
    SHUBHAM JAIN
  • panic mode
    1,267
    13,033
    • October 17, 2019 at 9:07 PM
    • #12
    It is exactly what it tells in the screen-capture of manual i shared in previous post.
