Cycle time on KRC2
  • DannyDJ
  • May 27, 2014 at 8:15 AM
  • DannyDJ
    67
    506
    I have one problem on KRC 2 with the L150 extention. I would like to save some cycle time. The robot picks some object in 2 diferent ways(one time rotating only axis 6 while moving to drop position) and one time without rotating axis 6. If robot rotates the object 180 degrees(axis 6) the robot is almost 3 seconds slower if not rotating the object. the diference is only the ptp where it rotates , everything else is at maximum(speeds, accel).
    Would it be maybe better if i split rotating 180 PTP to two 90 degrees PTP motions or i increase the $VEL_AXIS_MA[6] in the machine.dat cause it is really annoying that axis 6 slows down the robot so much.
  • eusty
    721
    • May 27, 2014 at 9:27 AM
    I have to say I'm no expert on speeding up robots, our process is VERY slow!
    But are you rotating A6 only in your move? I would have thought moving it alone (i.e. PTP {a6 45.0}) would have been the quickest way?
  • DannyDJ
    67
    506
    • May 27, 2014 at 9:44 AM
    It's rotating the A6 while moving. if it doesn't rotate A6 on the same lenght of the path, it is faster for about 3 seconds.
  • neranol
    33
    • May 28, 2014 at 4:40 PM
    hi,
    this is very weird. In a kr120 for instance, you can rotate axis n 6 284 degrees per second.
    What robot are we talking about??
  • panic mode
    1,297
    13,141
    • May 28, 2014 at 8:19 PM
    what is $VEL_AXIS_MA[6] set to?
  • DannyDJ
    67
    506
    • May 28, 2014 at 10:12 PM
    it is KR2210L150 robot, the $VEL_AXIS_MA[6]=4100, the KSS is 5.6.11. I did some tests on the robot with smaller payload KR150L110 the motor is the same, only diference is in $RAT_MOT_AX[6] gear ratio in machine.dat and the KR150L110 rotates faster A6.
  • DannyDJ
    67
    506
    • May 28, 2014 at 10:22 PM
    I just checked the manual for the robot KR2210L150 and the speed for axis 6 is 184/s compaired to KR150L110 which is 238/s.
