Smartpad Touchscreen Badly Wrong!
  • fazza85
  • May 12, 2014 at 9:32 AM
  • fazza85
    52
    Morning all,
    I am currently in Norway looking at a few problems with a customers robot. The main one seems to be the touch screen on his smartpad. It boots up and everything is fine but within 2 minutes it is badly uncalibrated. You can't touch ANYTHING correctly. I have plugged in a brand new pad and it's the same. Not sure what it could be?
    Sent from my SM-N9005 using Tapatalk
  • fazza85
    52
    • May 12, 2014 at 10:15 AM
    Robot is a KRC4 KR210 R2700. The robot itself is in a freezer, temp is -5C but the cabinet is in a room which is about 10C. I thought maybe something to do with temperature?
  • the leg
    643
    • May 12, 2014 at 11:43 AM
    have you calirated the touch pad you need a keyboard plugged into the smart pad
    turn the key press the robot button select calibration might be in german
    follow the screen instructions good luck craig !!
  • fazza85
    52
    • May 12, 2014 at 11:51 AM
    I've tried the screen calibration but I can't press any of the crosses because it doesn't recognise where I am pressing. The screen occasionally goes back to normal then goes uncalibrated at random! Do you work for Kuka by any chance?
  • the leg
    643
    • May 12, 2014 at 11:59 AM
    I may have :winking_face:
    Sent from my Nexus 5 using Tapatalk
  • SkyeFire
    1,060
    9,456
    • May 12, 2014 at 3:00 PM
    I've got a near-dozen KRC4s in the field with about a 50% incidence rate of a similar problem -- the SmartPad touch calibration seems to "drift" over time, and it's a bit of a crapshoot whether re-doing the calibration will actually do anything. And even when the re-calibration works, it generally drifts again given a few weeks.
    From what I've seen so far, it's in the Pads, not the robots. But I don't understand why this keeps happening -- these SPs are not being abused or exposed to any harsh environmental conditions (stable room temperature, no abrasives, corrosives, liquids, or weld slag, etc).
  • fazza85
    52
    • May 12, 2014 at 3:55 PM
    SkyeFire,
    This "uncalibration" seems to be within a few minutes of booting, and is easily 100 mm in the wrong place if you touch anything. Completely unusable. I've had to resort to using a wireless keyboard and mouse.
  • the leg
    643
    • May 12, 2014 at 3:57 PM
    Cheap Chinese tablets me thinks
  • ROBOTSTEVE
    • December 21, 2016 at 12:29 PM
    Hi Everyone,
    We have the same problem... just saying :baseball:
    Drifting calibration is very dangerous as the wrong characters are being changed, line jumping etc.
    Has caused many more hours programming and super re-checking.
    The lower half of the screen seems worse than the top.
    :wallbash:
  • Bad_block
    95
    • January 18, 2019 at 12:37 PM
    Hi there,
    I have the same problem, the lower part of SmartPad is working worst than higher.
    I calibrated it but after 5 minutes the problem returns.
    I took a SmartPad Main board from other SmartPad, and the touchscreen was working perfectly, but I don't know what can I do to fix it, a new main board is very expensive.
    If someone have already solved this problem, please tell me.
    Sulivan - Automatikbr.com
    Robotics Technician Brazil.
  • Bad_block
    95
    • March 21, 2019 at 1:39 PM
    • #11
    Are there some news??
  • panic mode
    1,296
    13,136
    • March 21, 2019 at 1:44 PM
    • #12
    solution is to be reasonable with use of smartPad and not kick it around, drop it etc. :icon_frown:
    otherwise it gets expensive....
  • SEAN-DUDE
    65
    • March 24, 2019 at 11:14 AM
    • #13
    Band Aid Solution: Get a USB Bluetooth mouse and key board :biggrins:
