Step by step procedure for welding machine calibration
  • amarkangda
  • April 19, 2014 at 11:05 AM
  • amarkangda
    50
    Can someone explain me a step by step procedure of calibrating the welding machine Motoweld S500.
    I have done it before but i dont remember.
    I remember that we have to create a test job for welding a test bead on a scrap component.
    Start from VWELD 1.0 and go upto VWELD 14.0
    But how about the AWELD values. What should that be initially.
    Please explain or share a manual if it exists.
    Thanks.
  • Pcarbines
    292
    • April 20, 2014 at 12:06 AM
    Hi , see attached manual , PLEASE note I will remove this manual within 7 days or prior if requested .
    we calibrate our welders in several ways & I'm not completely familiar with this machine.
    I would add that trying to get the robots welding file values to match the welders output exactly , is not always
    feasible , as changes to welding wire, base metal & conditions will influence these values.
    Edited once, last by Pcarbines (April 25, 2014 at 9:32 PM).
  • amarkangda
    50
    • April 25, 2014 at 11:30 AM
    I very much appreciate your help but i have this manual for my machine.
    May be i was not clear in my question, but i actually need to know the sample program that has to be written and what values to keep constant and what values to keep increasing.
    Thanks for the help.
  • kscoggins
    8
    • April 25, 2014 at 3:25 PM
    Welder calibration to robot output is do everything in the scaling file in the teach pendant. Menu. Welding. Welder Config.
    Sent from my SCH-I545 using Tapatalk 2
  • Pcarbines
    292
    • April 27, 2014 at 6:30 AM
    Hi , Please advise what controller you are using NX or DX
    Do you have the Operators Manual (for Arc Welding) if so look for chapter 9.?? "Power Source Condition File".
    Send me a PM with email address and Ill fwd manual & explanation.
